RPM for CentOS 8 won't install due to missing dependency
dflick
Post by dflick »
RPM install fails to find perl-List-MoreUtils on CentOS 8
I have the following pre-requisites installed on a fully patched minimal CentOS 8 install:
yum install epel-release -y
yum config-manager --enable PowerTools
However, from the pre-requisites repo page subscription-manager does not exist in CentOS (it is a Red Hat only package) so this command fails:
subscription-manager repos --enable codeready-builder-for-rhel-8-x86_64-rpms
I found documentation that shows that perl-List-MoreUtils should be available in the PowerTools repo in CentOS 8 but a "yum whatprovides" perl-List-MoreUtils fails to find it with PowerTools enabled.
I am trying to do this in automation so I want to make sure that dnf can maintain the install once it is running in production. If I manually install perl-List-MoreUtils from the individual rpm as a local file, it will not be updated down the road so I would much prefer to pull from a repo.
Re: RPM for CentOS 8 won't install due to missing dependency
Try running the following to clear out the repository cache so it can be recreated.
Run this.
dnf clean all
Then see if you can install the perl-List-MoreUtils package.
dnf install perl-List-MoreUtils
If it still does not install, run the following as root and post the output here.
dnf repolist
dnf list |grep perl-List-MoreUtils
dflick
Post by dflick »
I had read that and tried already but no go. I also tried resetting the yum database.
I did manage to get much further though. The ISO I have for 8 was not current so I did a dnf update and upgraded all the packages. This still did not fix the repo issue but after I rebooted, the PowerTools command finally ran. I updated my automation to do a dnf update and a reboot and it looks like all is working now.
I am running across another issue that may or may not be related to the new Nagios install on CentOS8 where we have a plugin that copies CISCO-EIGRP-MIB.py to /usr/lib/python2.7/site-packages/pysnmp_mibs/ directory. On V8 that directory does not exist on Python 3 and I get this error:
Destination directory /usr/lib/python3.6/site-packages/pysnmp_mibs does not exist
Any idea where this was moved to in CentOS 8 / Nagios XI?
I ran the pip3 install to install the Python MIB files that you posted about.
pip3 install pysnmp-mibs
And it installed them in this folder on a Centos 8 system.
/usr/local/lib/python3.6/site-packages/pysnmp_mibs
