REST API for CISCO ACI to monitor leaf and spine
aiqbal88
Post by aiqbal88 »
Is anyone using Rest API for CISCO ACI to monitor Leaf and Spine
benjaminsmith
Re: REST API for CISCO ACI to monitor leaf and spine
Post by benjaminsmith »
HI @aiqbal88,
That's a good question. In 5.7.x, we have a built-in JSON wizard which makes setting up checks from REST API endpoints easy to setup.
https://www.nagios.com/news/2020/06/nag ... 7-is-here/
The challenge is then what metrics do you need to monitor and are they available in the API. Below are a few links I've found to help to get you started.
Reference:
Monitoring APIC Using the REST API
Technote: SNMP in the ACI Fabric
Monitor Cisco ACI via REST-API
