Hello everyone!
I'm asking if any one has use/found a native XI solution for being able to use the Windows NCPA agent to monitor a windows folder for its existence as well as checking if the number of files are in a defined threshold? I see an XI plugin called "folder_watch.pl" but looks non-windows use. I've glanced around, but don't see a native way to do this outside of using a event handler to call on a service check to another custom script in the NCPA agent's /plugins/ directory. I rather not have to write scripts if it can be avoided. Has anyone in the community solved this item? All feedback/suggestions greatly appreciated. Thanks!
Monitor Folder/Files Counts for NCPA Windows Clients
jstormshak
Re: Monitor Folder/Files Counts for NCPA Windows Clients
There is no built-in file/folder checks at this time in NCPA. You can submit a feature request here if you would like that functionality to be built-in:
https://github.com/NagiosEnterprises/ncpa/issues
Technically, folder_watch.pl is meant for linux/unix systems but you can run plugins of any language the remote system supports. (meaning you can install perl/python/go/whatever support on the remote system to run perl/python/go/whatever) but it's up to the plugin if it supports windows or not.
You also don't use an event handler for this, you just call the plugins API endpoint to call the plugin on the system:
https://www.nagios.org/ncpa/help.php#ap ... es-plugins
One of the best parts of NCPA is if you go to https://YOURNCPAHOST:5693 and click the API it will show you what options are available and can help you construct the commands you need. Once you get one setup if you click the Run as a nagios check box another button on the bottom left shows up, if you click that View in alternative format button and click Active or Passive it will show you what command you should use.
See here as well:
This should do it:
https://exchange.nagios.org/directory/P ... s1/details
Or this one:
https://exchange.nagios.org/directory/P ... in/details
Let us know if you have any questions.
See here as well:
This should do it:
Or this one:
jstormshak
Thanks for the reply and feedback. I ended up pulling the "check_windows_files" and put it through some testing. This will meet my needs nicely. Thanks again!
Great!jstormshak wrote:Thanks for the reply and feedback. I ended up pulling the "check_windows_files" and put it through some testing. This will meet my needs nicely. Thanks again!
Locking thread
