Hi guys,
I'm asking for support because I have wasted a lot of my time trying to find solution on google without succes.
I'm trying to configure a probe to check some criteras into my mariadb sql base. The pluggin i'm installation is check_mysql_query.
But this plugging is not detected by my nagios server.
this is the shema of my infrastructure :
UBUTUN VM Wordpress server with an NRPE + MARIA DB ------------------------------------------ UBUTUN WN with nagios server
the goal is to monitor the worpress sql base and check when more than 4 comments are posted.
See bellow my NRPE.CFG file + interface screenshot
https://ibb.co/HrY5dpL
If someone have a clue ?
Thanks in advance
Nagios core pluggin not detected Mysql_query
nrpe.cfg- (13 KiB) Downloaded 134 times
benjaminsmith
Re: Nagios core pluggin not detected Mysql_query
It might be the permissions on the plugin, log in to the server as the Nagios user, and try running the full plugin. Do you get valid results back?
Let me what you find out.
Benjamin
su - nagios
/usr/local/nagios/libexec/check_mysql_query -H localhost -u test -p test -d wordpress -q "SELECT COUNT(c.comment_date) FROM wp_comments as c where hour(timediff( localtime(), c.comment_date )) < 4" -w 4 -c 10
Benjamin
