Clearing snapshots
hcltech
Clearing snapshots
Post by hcltech »
I had to redo my servers and attached to my offsite storage for snapshots before i removed them. Now that I have cleaned it out they are still showing up in the snapshot list. Is there a way to clear these out of nagios log server?
Re: Clearing snapshots
If you want to delete all the snapshots you need to gran the name of the repository from Admin -> Snapshots & Maintenance in the repository section and then replace <repository> in the command below and run from the CLI
Note: This will delete all snapshots and is not reversible
curl -XDELETE localhost:9200/_snapshot/<repository>/*
hcltech
Post by hcltech »
{"error":"InvalidSnapshotNameException[[QNAP:*] Invalid snapshot name [*], must not contain the following characters [\\, /, *, ?, \", <, >, |, , ,]]","status":400}root@cl-p-nagioslog01
Can you delete them through the GUI?
hcltech
Post by hcltech »
I tried that first it just sits there forever and does nothing.
cdienger
Post by cdienger »
Give this a try:
/usr/local/nagioslogserver/scripts/curator.sh delete snapshots--all-snapshots --repository 'REPOSITORY_NAME'
hcltech
Post by hcltech »
It looked like that errored out as well but it created a bunch of files in the repository. I went in and deleted all those and now my storage snapshots list is clear in the UI. Thank you.
cdienger
Post by cdienger »
Odd that it would give you an error. If you run into the error again on the new setup please open a new thread and we'll take a look.
