Nagios and check_mk integration
emi65
Post by emi65 »
Hi expert
I'm using nagios core 4.5.1
I like to know is there a way to integrate in nagios the check did in check_mk monitoring application
I know (because I read the check_mk site) that is possible to use a api command ( lq ) or use
curl to downloda info in check_mk web user interface
Do you know if exist another modality ?
thanks and regards
Emilio
