NagiosXI 5.6.14 - Current Check not getting updated...
Hi Team,
NagiosXI 5.6.14
Nagios Core 4.4.5
mod_gearman
I noticed that With below settings "Current Check" is not getting updated, but Last Check and Next Check seems to be getting updated :
max_check_attempts 10
check_interval 5
retry_interval 2
Force an immediate Check 1st attempt
Force an immediate Check 2nd attempt
Force an immediate Check 3rd attempt Kindly assist.
Regards,
Vish.
NagiosXI 5.6.14
Nagios Core 4.4.5
mod_gearman
check_interval 5
retry_interval 2
Regards,
Vish.
Re: NagiosXI 5.6.14 - Current Check not getting updated...
I'd like to get a profile from the XI server which can be generated under Admin > System Config > System Profile > Download Profile, or from the command line with:
The profile is then saved to /usr/local/nagiosxi/var/components/profile.zip.
The profile can have sensitive information so please send it to me in a private message.
/usr/local/nagiosxi/scripts/components/getprofile.sh 60642
I don't see any obvious issues at the moment. This may be related to the mod gearman config. Try removing this as a factor by editing /usr/local/nagios/etc/nagios.cfg and comment out this line:
and restarting the nagios process:
Then again force the checks to run and see if the count updates. Feel free to revert the nagios.cfg back after testing.
#broker_module=/usr/lib64/mod_gearman/mod_gearman_nagios4.o config=/etc/mod_gearman/module.conf eventhandler=noCode: Select all
systemctl nagios restartAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Disabling mod_gearman didnt make any difference.
Here is the config entry , please let me know if anything is wrong here.
Regards,
Vish.
Regards,
Vish.
It looks like the max check attempts is set to 10 but the previous screenshots shows 6. Was this changed or is this another symptom of the problem?
I'd like to get the output of the following commands. You can send the output of these to me in a private message:
echo "describe nagios_servicestatus;" | mysql -uroot -pnagiosxi -Dnagios --table > description.txt
echo "select * from nagios_servicestatus;" | mysql -uroot -pnagiosxi -Dnagios --table > servicestatus.txtAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
The configuration for the check appears different than how it is showing up in the text file so it may be an issue with parsing some of the characters. Please provide a copy of the CCM database as well as the host and service name. Please PM these to me.
The CCM database can be written to a file called nagiosql.sql with:
mysqldump -uroot -pnagiosxi nagiosql > nagiosql.sqlAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
The service no longer appears to be in the CCM or it has been changed. The behavior you're seeing is likely a result of the configuration not applying or loading all the way. To be clear - this is occurring just for the one service?
Update the php.ini per https://support.nagios.com/kb/article/n ... e-611.html and then rewrite and apply the configuration in the CCM. Do this by going to Configure > Core Config Manager > Tools > Config File Management, and clicking:
-Delete Files
-Write Configs
-Verify Files
-Restart Nagios Core
and then apply the configuration again under Configure > Quick Tools > Apply Configuration.
-Delete Files
-Write Configs
-Verify Files
