I currently have a check setup with the following settings.
host_name servername
service_description MSSQL Query - ImageNow Extern Messaging
use xiwizard_mssqlquery_service
check_command check_xi_mssql_query! "Expected result" --decode --warning 50 --critical 200 --querywarning 30000 --querycritical 31000 --result Expected result!!!!!!!
is_volatile 1
max_check_attempts 3
check_interval 5
retry_interval 1
active_checks_enabled 1
passive_checks_enabled 1
check_freshness 1
flap_detection_enabled 0
process_perf_data 1
retain_status_information 1
notification_interval 30
first_notification_delay 0
notification_options c,u,r,f,
notifications_enabled 1
contact_groups usergroup1,usergroup2,usergroup3
_xiwizard mssql_query
register 1
But for some reason I am receiving notifcications from nagios every 6 minutes instead of 30. Templates that are associated with this service check also have a 30 minute notification interval. Can you help me understand why this is the case?
Notification time not followed?
Re: Notification time not followed?
I don't see an obvious reason for the behavior your'e describing. Are the notifications all the same, ie all CRITICAL or WARNING notifications with the same details?
Please send me a copy of a profile as well as a copy of the ccm database in a private message. A profile can be generated under Admin > System Config > System Profile > Download Profile, or from the command line with:
The profile is then saved to /usr/local/nagiosxi/var/components/profile.zip.
If the default database is being used then it can be gathered from the command line with:
If the database has been offloaded to another machine then you'll need to modify the commands slightly to look like:
/usr/local/nagiosxi/scripts/components/getprofile.sh 60655If the default database is being used then it can be gathered from the command line with:
mysqldump -uroot -pnagiosxi nagiosql > nagiosql.sqlCode: Select all
mysqldump -h database_host_ip -uusername -ppassword nagiosql > nagiosql.sqlAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Profile and database have been sent via PM.
The service is configured as a volatile service. This means a it behaves differently in a few ways. One of them being that each time it is checked and found to be in a hard non-OK state, notifications are sent and notification intervals are ignored.
https://assets.nagios.com/downloads/nag ... vices.html
