Nagios XI upgrade Error
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
We are upgrading Nagios XI from 5.6.14 to 5.7.4 latest version but we are getting below error.
[root@eu1papu003 yum.repos.d]# cd /tmp
[root@eu1papu003 tmp]# cd nagiosxi/
[root@eu1papu003 nagiosxi]# ./upgrade
IMPORTANT: Before upgrading, verify you have both a valid system backup as well as a configuration backup of Nagios XI before continuing! More information
about backing up and restoring Nagios XI can be found here: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
NOTICE: Your Nagios XI license includes a test environment instance that allows you to verify successful upgrade and configuration changes before applying
them to your production environment. As a best practice for ensuring the reliability of your monitoring systems, we advise you to upgrade your test environment
before upgrading any production instances. More information on licensing can be found here: https://assets.nagios.com/handouts/nagi ... Policy.pdf
Are you sure you want to continue? [y/N] y
Proceeding with upgrade...
Nagios XI Upgrade Log
DATE: Sun 8 Nov 03:35:13 GMT 2020
DISTRO INFO:
CentOS
7.8.2003
x86_64
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.4.lin
Sourceguardian extension found for PHP version 5.4
Sourceguardian extension already in php.ini
Checking required prereqs...
Please wait...
OLD VERSION: 5614
Loaded plugins: fastestmirror
Determining fastest mirrors
* epel: mirror.in2p3.fr
No packages marked for update
Examining /tmp/nagiosxi/nagiosxi-deps-el7-5.7.4-1.noarch.rpm: nagiosxi-deps-el7-5.7.4-1.noarch
Marking /tmp/nagiosxi/nagiosxi-deps-el7-5.7.4-1.noarch.rpm as an update to nagiosxi-deps-el7-5.6.14-1.noarch
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi-deps-el7.noarch 0:5.6.14-1 will be updated
---> Package nagiosxi-deps-el7.noarch 0:5.7.4-1 will be an update
--> Processing Dependency: git for package: nagiosxi-deps-el7-5.7.4-1.noarch
Loading mirror speeds from cached hostfile
Error: Package: nagiosxi-deps-el7-5.7.4-1.noarch (/nagiosxi-deps-el7-5.7.4-1.noarch)
Requires: git
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Cleaning repos: epel
Cleaning up list of fastest mirrors
Other repos take up 107 M of disk space (use --verbose for details)
* epel: mirrors.nav.ro
Requires: git
Could you please suggest steps to fix it.
Nitin Parate
Thanks & Regards,
I2MP Team.
dchurch
Re: Nagios XI upgrade Error
Post by dchurch »
Evidently yum cannot find the "git" package. Perhaps the repo list changed, possibly by something adding or removing files in /etc/yum.repos.d/. No matter, we can re-enable some repos to try to fix it.
Try opening /etc/yum.repos.d/CentOS-Base.repo in your text editor of choice and removing any lines that say enabled=0.
Then:
sudo yum clean all
Then try the installer again.
If that doesn't work, can you post the output of the following command?
sudo yum list git
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
PFB details and suggest next steps to fix it.
nagios@10.144.223.156's password:
Last login: Sun Nov 8 02:53:46 2020 from 10.148.141.196
[nagios@eu1papu003 ~]$ sudo su - root
[sudo] password for nagios:
Last login: Sun Nov 8 02:53:55 GMT 2020 on pts/0
[root@eu1papu003 ~]# cd /etc/yum.repos.d/
[root@eu1papu003 yum.repos.d]# ls -lrth
total 8.0K
-rw-r--r-- 1 root root 1.1K Sep 22 03:30 epel-testing.repo
-rw-r--r-- 1 root root 947 Nov 8 04:36 epel.repo
[root@eu1papu003 yum.repos.d]# sudo yum clean all
You have new mail in /var/spool/mail/root
[root@eu1papu003 yum.repos.d]# sudo yum list git
epel/x86_64/metalink | 8.3 kB 00:00:00
* epel: mirrors.ukfast.co.uk
epel | 4.7 kB 00:00:00
(1/3): epel/x86_64/group_gz | 95 kB 00:00:00
(2/3): epel/x86_64/updateinfo | 1.0 MB 00:00:02
(3/3): epel/x86_64/primary_db | 6.9 MB 00:00:02
Error: No matching Packages to list
Nitin Parate
Thanks & Regards,
I2MP Team.
ssax
Dreams In Code
Post by ssax »
It doesn't look like you have access to the proper repositories, what is the output of this command?
yum repolist all
Here are the ones I have enabled, you're missing everything but epel:
base/7/x86_64                                CentOS-7 - Base                                                             10,070
epel/x86_64                                  Extra Packages for Enterprise Linux 7 - x86_64                              13,466
extras/7/x86_64                              CentOS-7 - Extras                                                              413
updates/7/x86_64                             CentOS-7 - Updates                                                           1,134
You can do this:
yum install yum-utils -y
yum-config-manager --enable 'CentOS-7 - Base'
yum-config-manager --enable 'CentOS-7 - Extras'
yum-config-manager --enable 'CentOS-7 - Updates'
Then run the upgrade again.
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
Please find below details. We have not tried to run the upgrade again since all below commands failed.
Please check and suggest next steps to resolve the issue and get the Environment upgraded.
[root@eu1papu003 nagiosxi]# yum install yum-utils -y
One of the configured repositories failed (Unknown),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=<repoid> ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable <repoid>
or
subscription-manager repos --disable=<repoid>
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: base/7/x86_64
[root@eu1papu003 nagiosxi]# yum repolist all
epel/x86_64/metalink | 29 kB 00:00:00
epel/x86_64 | 4.7 kB 00:00:00
repo id repo name status
base/7/x86_64 CentOS-7 - Base enabled: 0
base-source/7 CentOS-7 - Base Sources disabled
centos-kernel/7/x86_64 CentOS LTS Kernels for x86_64 disabled
centos-kernel-experimental/7/x86_64 CentOS Experimental Kernels for x86_64 disabled
centosplus/7/x86_64 CentOS-7 - Plus enabled: 0
centosplus-source/7 CentOS-7 - Plus Sources disabled
cr/7/x86_64 CentOS-7 - cr disabled
*epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 enabled: 0
epel-debuginfo/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 - Debug disabled
epel-source/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 - Source disabled
epel-testing/x86_64 Extra Packages for Enterprise Linux 7 - Testing - x86_64 disabled
epel-testing-debuginfo/x86_64 Extra Packages for Enterprise Linux 7 - Testing - x86_64 - Debug disabled
epel-testing-source/x86_64 Extra Packages for Enterprise Linux 7 - Testing - x86_64 - Source disabled
extras/7/x86_64 CentOS-7 - Extras enabled: 0
extras-source/7 CentOS-7 - Extras Sources disabled
updates/7/x86_64 CentOS-7 - Updates enabled: 0
updates-source/7 CentOS-7 - Updates Sources disabled
repolist: 0
Thanks & Regards,
I2MP Team.
dchurch
Post by dchurch »
Are you sure you have a reliable network connection? The repo failing could mean your internet connection isn't working. Sometimes VM settings can outright break the internet connection.
ping -c 5 google.com
If it turns out nothing is wrong with your network, please post the contents of /etc/yum.repos.d/CentOS-Base.repo.
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
PFB details:
[root@eu1papu003 ~]# ping -c 5 google.com
PING google.com (216.58.210.46) 56(84) bytes of data.
64 bytes from lhr25s11-in-f14.1e100.net (216.58.210.46): icmp_seq=1 ttl=115 time =4.23 ms
64 bytes from lhr25s11-in-f14.1e100.net (216.58.210.46): icmp_seq=2 ttl=115 time =4.20 ms
64 bytes from lhr25s11-in-f14.1e100.net (216.58.210.46): icmp_seq=3 ttl=115 time =4.29 ms
64 bytes from lhr25s11-in-f14.1e100.net (216.58.210.46): icmp_seq=4 ttl=115 time =4.20 ms
64 bytes from lhr25s11-in-f14.1e100.net (216.58.210.46): icmp_seq=5 ttl=115 time =4.17 ms
--- google.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 4.171/4.222/4.298/0.059 ms
Kindly suggest on next steps.
Nitin Parate
Thanks & Regards,
I2MP Team.
dchurch
Post by dchurch »
Please post the contents of /etc/yum.repos.d/CentOS-Base.repo.
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
PFB requested details. kindly check and suggest next steps to fix the upgrade issue.
[nagios@eu1papu003 yum.repos.d]$ ls
CentOS-Base.repo CentOS-Sources.repo epel.repo
CentOS-CR.repo CentOS-x86_64-kernel.repo epel-testing.repo
[nagios@eu1papu003 yum.repos.d]$ cat CentOS-Base.repo
# CentOS-Base.repo
# The mirror system uses the connecting IP address of the client and the
# update status of each mirror to pick mirrors that are updated to and
# geographically close to the client. You should use this for CentOS updates
# unless you are manually picking other mirrors.
# If the mirrorlist= does not work for you, as a fall back you can try the
# remarked out baseurl= line instead.
[base]
name=CentOS-$releasever - Base
mirrorlist=http://mirrorlist.centos.org/?release=$ ... earch&repo =os&infra=$infra
#baseurl=http://mirror.centos.org/centos/$releas ... $basearch/
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
#released updates
[updates]
name=CentOS-$releasever - Updates
mirrorlist=http://mirrorlist.centos.org/?release=$ ... earch&repo =updates&infra=$infra
gpgcheck=1
#additional packages that may be useful
[extras]
name=CentOS-$releasever - Extras
mirrorlist=http://mirrorlist.centos.org/?release=$ ... earch&repo =extras&infra=$infra
gpgcheck=1
#additional packages that extend functionality of existing packages
[centosplus]
name=CentOS-$releasever - Plus
mirrorlist=http://mirrorlist.centos.org/?release=$ ... earch&repo =centosplus&infra=$infra
gpgcheck=1
Thanks & Regards,
I2MP Team.
dchurch
Post by dchurch »
This sort of error can be caused by a "hiccup" in the CentOS repositories. Try clearing the yum cache with this command:
yum clean all
