Make NCPA plugins return status
taxidis
Post by taxidis »
Hi there,
I am trying to migrate nrpe plugins to ncpa plugins but having some basic issues so far.
I call the remote plugin which executes successfully and return the wanted message but it does not return status code (WARNING, CRITICAL etc.) .
The remote script returns those codes upon execution but nagios can not get as it seems. I found in the knowledge base that custom plugins do not support builtin critical and warning flags but I cannot find a way to make this work.
note: It does not help that all google search results are about nrpe.
Thanks in advance.
benjaminsmith
Re: Make NCPA plugins return status
Post by benjaminsmith »
Hi @taxidis,
As long as it's returning a valid exit code it should work, can you run the full check command from the Nagios Server terminal, and post the output or a screenshot of the error to the thread?
Follow the steps in the knowledgebase article below to get the check command and test it from the CLI.
Nagios XI - How To Test Check Commands From The Command-line
Also, check_ncpa.py has a verbose output option -v, please add that to the command string for additional data.
Thanks, Benjamin
