Hi Support,
How can we get AVERAGE of Month from bandwidth RRD files. While looking on internet found rrdtool graph command but not sure how to use it in this case. Can you please help.
For Eg.
from rrdtool fetch command we are getting list of values in 30 min average. We need a single line output for the day and month.
Please guide me to achieve this.
How to get average of month from specific rrd file
capgemtools
Supriya
Supriya
Re: How to get average of month from specific rrd file
You've probably run a command like this:
which will give yo the values for the start and stop ranges specified. I believe this is the extent of what the rrdtool can do to provide you the information you're looking for so you'll need to take whatever steps that work in your environment to manipulate the data into a format you're looking for.
rrdtool fetch filename.rrd AVERAGE --start 1605039240 --end 1605040240As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
