All,
I am trying to do an offline installation of Nagios XI 5.7.4. My server has a RHEL 7 OS and our unix team downloads rpm repositories for use locally. I am stuck trying to obtain the following 2 rpms to complete the installation. They are: pmyssql and mysql-server. Can you tell me where I can obtain these rpm's. I haven't been able to find them in any of our local repositories.
Thank you for your assistance!!!
Nagios XI 5.7.4 offline installation missing rpms
Re: Nagios XI 5.7.4 offline installation missing rpms
The package for providing a MySQL-compatible server in RHEL7 and CentOS 7 is called mariadb-server.
And the package providing the Python library "PyMSSQL" is called python2-pymssql.
As far as where to download them, that would depend on your environment, but hopefully this helps your search.
All,
I installed the rpms you mentioned in your response and got the following error:
Transaction check error:
file /usr/bin/my_print_defaults from install of mariadb-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/my_print_defaults.1.gz from install of mariadb-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/innochecksum from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/myisam_ftdump from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/myisamchk from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/myisamlog from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/myisampack from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/mysql_secure_installation from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/mysql_tzinfo_to_sql from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/mysql_upgrade from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/mysqldumpslow from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/bin/perror from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/innochecksum.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/myisam_ftdump.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/myisamchk.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/myisamlog.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/myisampack.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/mysql_secure_installation.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/mysql_tzinfo_to_sql.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/mysql_upgrade.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/mysqldumpslow.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
file /usr/share/man/man1/perror.1.gz from install of mariadb-server-1:5.5.68-1.el7.x86_64 conflicts with file from package rh-mysql80-mysql-server-syspaths-8.0.21-1.el7.x86_64
Error Summary
What do I do now???
Error Summary
What do I do now???
I didn't realize you had already installed some packages of MySQL 8.0.
You'll need to remove mariadb-server by running:
Then the package to install the missing server component of MySQL 8.0 is called rh-mysql80-mysql-server.
rpm -e mariadb-serverIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
I have tried your suggestions without success. The "offline" install still insists on the following rpms:
Error: Package: nagiosxi-deps-5.7.4-1.noarch (/nagiosxi-deps-5.7.4-1.noarch)
Requires: pymssql
Requires: mysql-server
Any suggestions?
Thank you in advance for all your help.
Requires: pymssql
Any suggestions?
All,
Somehow, the problem disappeared. Thank you for your help.
Glad to hear!
Let us know if you have any related questions or if we're okay to lock this up and mark it as resolved.
