[root@redacted ndo]# systemctl status ndo2db.service
● ndo2db.service - LSB: Nagios NDO2DB Initscript
Loaded: loaded (/etc/rc.d/init.d/ndo2db; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2020-11-13 13:11:47 CET; 11min ago
Docs: man:systemd-sysv-generator(8)
Process: 13560 ExecStart=/etc/rc.d/init.d/ndo2db start (code=exited, status=1/FAILURE)
Nov 13 13:11:47 redacted.domain.ext systemd[1]: Starting LSB: Nagios NDO2DB Initscript...
Nov 13 13:11:47 redacted.domain.ext ndo2db[13560]: Executable file /usr/local/nagios/bin/ndo2db not found. Exiting.
Nov 13 13:11:47 redacted.domain.ext systemd[1]: ndo2db.service: control process exited, code=exited status=1
Nov 13 13:11:47 redacted.domain.ext systemd[1]: Failed to start LSB: Nagios NDO2DB Initscript.
Nov 13 13:11:47 redacted.domain.ext systemd[1]: Unit ndo2db.service entered failed state.
Nov 13 13:11:47 redacted.domain.ext systemd[1]: ndo2db.service failed.
[root@redacted ndo]# /usr/local/nagios/bin/ndo2db --version
-bash: /usr/local/nagios/bin/ndo2db: No such file or directory
The nagios.cfg seems to be updated correctly, with the new broker line
Also, Nagvis is not working anymore after the update.
The backend with the ID "live_1" is not defined.
The backend with the ID "nagiosxi" is not defined.
