I have a nagiosxi2.2 registered. I tried to upgrade to version 3.0. Unfortunately I get the following error message
nagiosxi-deps-2011r3.0-1.noarch from /nagiosxi-deps-2011r3.0-1.noarch has depsolving problems
--> Missing Dependency: rrdtool-python is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: numpy is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: python-lxml is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: perl(Net::SMTP::TLS) is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: perl-Net-SNMP is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: python-matplotlib is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: php-pear-HTML-Template-IT is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: graphviz is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
--> Missing Dependency: scipy is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: graphviz is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: perl(Net::SMTP::TLS) is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: perl-Net-SNMP is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: rrdtool-python is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: python-lxml is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: scipy is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: python-matplotlib is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: numpy is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Error: Missing Dependency: php-pear-HTML-Template-IT is needed by package nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
I tried to follow the recommended instructions. I still have the problem. How can I do?
thanks
Diego
upgrade nagiosxi from version 2.2 to 3.0
Re: upgrade nagiosxi from version 2.2 to 3.0
These shouldn't be blocking, the upgrade should have completed after this and after logging out and back in as an Admin you should see the version upgrade...
