Ping check with rta and pl alarms
davide.bonicelli
Post by davide.bonicelli »
Hi, with the standard check_ping plugin the alarms are for rta OR pl%
is there a way to have an alarm for rta AND pl% over the limits?
for example, if i put an alarm like this 100,20% i'd like to receive the mail if rta is >100 and pl>20%
benjaminsmith
Re: Ping check with rta and pl alarms
Post by benjaminsmith »
Hi @davide.bonicelli,
There are few more ping checks available on the Nagios Exchange, but I was unable to find a plugin that had that kind of logic built into it.
I would take a look a the check_icmp plugin as it is a little more flexible as far as passing arguments.
https://www.monitoring-plugins.org/doc/ ... _icmp.html
davide.bonicelli
thanks but it has the same logic..rta OR pl%, not AND
ibut i can survive to this :)
benjaminsmith
I wish could be more help on this one. You might try looking at some of the plugins on the Nagios Exchange, and use that as a template for creating a new one based on your requirements.
davide.bonicelli
yes i will try..a customer needs this type of check.. :cry:
benjaminsmith
HI,
Sounds good. We'll go ahead and close this topic, but feel free to open another if you have any new questions.
Best Regards,
Benjamin
