Hi
Is it possible to have more than one NCPA agent installed on the same server?
Its for scenarios where multiple nagios need to monitor the server and for political reasons cannot share same key.
rgds
George
Multiple NCPA agents on the same server
Re: Multiple NCPA agents on the same server
Yes, you should be able to make duplicates the installation directory and as long each copy's configuration uses a different port and you creates services to use the unique configs, it should work.
That said, we don't develop or test for this type of deployment so you'll want to test this in a lab before pushing it out.
