Nagios XI - Last Check Time Not Updating
since "2020-11-21 03:05:03" the last check result doesn't update only in Nagiosxi, in Nagios Core everything is fine.
Database repair script and reboot doesn't fix it.
e.g. https://support.nagios.com/kb/article.p ... %20checks).
https://assets.nagios.com/downloads/nag ... ptions.pdf
doesn't help.
Any Ideas?
doesn't help.
Any Ideas?
benjaminsmith
Re: Nagios XI - Last Check Time Not Updating
Hi @scharft,
When did this start happening? After an upgrade?
It looks like a ndo (database component) issue. If you can send me the system profile, I can review the logs and settings to double check.
Regards,
Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Regards,
Benjamin
Hi Benjamin,
this happening started last Saturday night, date & tiime you can see in the screenshot ~ 03:00:00 for all of the checks.
We upgraded Nagios XI to Version 5.7.5 after this problem, we hoped this will fix it.
The profile is attached.
thank you
best Regards
thomas
thank you
best Regards
thomas
benjaminsmith
Hi Thomas,
I'm going to reach out to the team on this issue, I'll update you shortly.
Regards,
Benjamin
Regards,
Benjamin
Hi Benjamin,
we had the same issue after apply a new configuraiton the days before the issue happen..
best Thomas
best Thomas
Attached to the post is an updated NDO3 broker.
Copy the mod-master.tar.gz file to the XI server and run the following to compile, install it and to restart nagios.
Save the file and then restart nagios.
See if this helps the issue you are having.
tar xvfz ndo-master.tar.gz
cd ndo-master
./configure
make all
make installCode: Select all
service nagios restart
Reason: Removed ndo-master file as it has been updated.
thank you.
the error has been fixed.
Can you please explain what was the problem?
best
thank you.
best
There was a bug in the older NDO3 broker that would not update the checks in the MYSQL database which the XI interface uses to display the data.
The new broker fixed that.
ok, thank you.
Can you check if we have an error in the ndo on our new server?
After applying a new configuration we have to wait ~10 - 30 minutes until the last check result updates the values.
This is shown => 18598d 13h 46m 31s 0/0 1970-01-01 00:00:01 No check results for service yet.
The systemprofile is attached
I am going to need to see the nagios.log file from the server to determine if there are any errors.
Restart nagios by running this.
Wait for an hour and post the /usr/local/nagios/var/nagios.log file so I can view it.
systemctl restart nagiosBe sure to check out our Knowledgebase for helpful articles and solutions!
