Nagios Xi not adhering to Local "Backup Limit"
paulconca
Post by paulconca »
Hi All
I had to changed the local backup location as the default one is low on space. The new location is /var/log/backups/nagiosxi/backups/ and this works fine, the issue is that I set the "Backup Limit" to 2 but it does not delete them.
So everyday I have to go and delete the third one.
Is there a script i need to update to remedy this?
Thank you
benjaminsmith
Re: Nagios Xi not adhering to Local "Backup Limit"
Post by benjaminsmith »
Hi @paulconca,
What version of Nagios XI are you currently using and which Linux Distribution? I just tested this on 5.7.4 and it does automatically remove the older archives in that folder.
Regards,
Benjamin
paulconca
Post by paulconca »
Hi
Its Nagios XI 5.7.3 (We cannot upgrade at the moment)
NAME="CentOS Linux"
VERSION="7 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="7"
PRETTY_NAME="CentOS Linux 7 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:7"
HOME_URL="https://www.centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
CENTOS_MANTISBT_PROJECT="CentOS-7"
CENTOS_MANTISBT_PROJECT_VERSION="7"
REDHAT_SUPPORT_PRODUCT="centos"
REDHAT_SUPPORT_PRODUCT_VERSION="7"
Thank you
benjaminsmith
Let's query to the database directly to check if the limit setting has been written correctly. Please post the output to the following command.
mysql -h 127.0.0.1 -uroot -pnagiosxi nagiosxi -e "select * from xi_options where name like 'scheduled%backups';"
Also, please send me the system profile as well. Thanks, Benjamin
To send us your system profile
Login to the Nagios XI GUI using a web browser.
paulconca
Post by paulconca »
I sent you the profile, via private message
here is the output for the local backup, the one which fails.
| 115 | scheduled_local_backups | a:9:{s:6:"active";i:1;s:4:"freq";s:5:"daily";s:3:"day";s:1:"0";s:5:"hours";s:2:"09";s:4:"mins";s:2:"30";s:3:"dir";s:34:"/var/log/backups/nagiosxi/backups/";s:5:"limit";s:1:"2";s:7:"lastrun";i:1606296602;s:7:"nextrun";i:1606383000;}
benjaminsmith
Hi @paulconca,
I think what is happening is that the permissions are not correct. I was able to repeat this condition. It can write to that custom folder but it is not able to remove the older archives.
What output do you get when you select the Test Permissions button from the Scheduled Backups page?
The permissions on the backup directory should be as follows.
drwxr-xr-x. 2 nagios nagios 6 Apr 17  2020 /store/backups/nagiosxi
chown nagios:nagios /var/log/backups/nagiosxi/backups/ -R
chmod 775 /var/log/backups/nagiosxi/backups/ -R
Then run another scheduled backup and it should remove the older archives.
paulconca
Post by paulconca »
For the test I get "The directory exists and is writeable."
Rights for the backup folder
drwxr-xr-x 2 nagios nagios 4.0K Nov 26 17:30 backups
Results after I run the above, the third back up, still remains and if you notice the rights are different on the one created by the backup -rw-r--r--
-rwxrwxr-x 1 nagios nagios 15G Nov 25 10:50 nagiosxi.1606296602.tar.gz
-rwxrwxr-x 1 nagios nagios 15G Nov 26 10:52 nagiosxi.1606383001.tar.gz
-rw-r--r-- 1 nagios nagios 15G Nov 26 17:30 nagiosxi.1606407002.tar.gz
ssax
Dreams In Code
Post by ssax »
What is the output of this command?
grep nag /etc/group
Please edit this file:
/usr/local/nagiosxi/html/includes/constants.inc.php
At the bottom, change this:
define('SB_LOGLEVEL', 3);
To this:
define('SB_LOGLEVEL', 0);
Then run this command as root (and leave it running):
tail -F /var/log/httpd/error_log /var/log/httpd/ssl_error_log /usr/local/nagiosxi/var/cmdsubsys.log /usr/local/nagiosxi/var/components/scheduledbackups.log
Then force a scheduled backup to run and after it's completed or failed, send me the entire output from the tail command above and send me this file:
paulconca
Post by paulconca »
[root@oeismon01 concannp]# grep nag /etc/group
nagios:x:1001:nagios,apache,snmptt
nagcmd:x:1002:nagios,apache,snmptt
I sent you the rest via private message.
Thank you
ssax
Dreams In Code
Post by ssax »
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
Please include this info in that new ticket as well:
- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the first command if your DB is offloaded to another server and/or you've changed the root mysql password
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
