Hi all
Very new to Nagios NA so apologies if this is a dumb question, have looked around forums but drawn a blank so far, and this is a bit old and quite limited https://support.nagios.com/kb/article/n ... s-800.html.
We use Ansible to provision our hosts, and to register them in NagiosXI and create services, etc. via the API. Is it possible to do a similar thing with sources in Network Analyzer?
Eg. in my hosts file I would have
10.1.2.3 hostname=myServer nagios_na_server=nagiosNaForThisNetwork nagios_na_port=1234
This would then give me the info I need to install my netflow forwarder, point that to the chosen port and Network Analyzer node, and create a source with the name of the server and the defined port on the appropriate Network Analyzer node.
Is that doable?
If not, be good to hear of any timesaving ways to set up lots of hosts quickly!
Cheers
Daniel
Create source via API
Re: Create source via API
The ability to add sources via the API isn't available at the moment, but you could add a new source by adding it directly to the database.
For example:
For example:
echo "insert into nagiosna_Sources(port, addresses, name, flowtype, directory, lifetime, disable_abnormal) values(9999,'5.6.7.8','test','netflow','/usr/local/nagiosna/var/test','48H',0);" | mysql -unagiosna -pnagiosna -Dnagiosna
echo "select * from nagiosna_Sources;" | mysql -unagiosna -pnagiosna -Dnagiosna As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
danielheaton
Thanks, that should be scriptable, cheers!
benjaminsmith
Grea! Did you have other questions or shall we close out this topic?
Cheers!
