Bug: MFA + Nagios Mobile
RelyIT
Post by RelyIT »
Hi!
We have enabled MFA/2FA for our users. If you didn't know it you can enable MFA/2FA under Admin > System Settings > Security > Two Factor Authentication (Email).
This has worked out great for users working on a PC/laptop with a normal browser.
But if we try to access our Nagios installation from a mobile device and use Nagios Mobile we can sign in but when we are supposed to be challenged with MFA/2FA we can only se a white/blanc page. The 2FA email is arriving in our mailbox but there is nowhere to insert the digits.
I would say this is a bug in Nagios XI!
We are currently running Nagios XI 5.7.5.
Thanks!
benjaminsmith
Re: Bug: MFA + Nagios Mobile
Post by benjaminsmith »
Hi @RelyIT,
Thank you for bringing this to our attention. I was able to repeat this behavior as well on my 5.7.5 test system. I'll get a bug report filed on this issue and it should be fixed in an upcoming maintenance release.
Let me know if you have any questions.
Benjamin
