NagiosXi - Update thresholds for multiple servers
Bala.Mutyam
Post by Bala.Mutyam »
In XI is there an options to update service check thresholds for multiple servers at a time? We have added checks using Configuration Wizard: Bulk Host Cloning and Import.
It seems to be not possible with the Bulk Modifications Tool.
Bala
Rfferrao13
Re: NagiosXi - Update thresholds for multiple servers
Post by Rfferrao13 »
Bala.Mutyam wrote: It seems to be not possible with the Bulk Modifications Tool.
Have you considered trying Change Command and Arguments in Bulk Modifications Tool?
Bala.Mutyam
I have tried but did seem to be working.
Bala.Mutyam
Here are the thresholds i'm trying to modify:
/usr/local/nagios/libexec/check_ncpa.py -H host_name -t 'token' -P 5693 -M user/count -w 2 -c 4
benjaminsmith
Post by benjaminsmith »
Hi @Bala.Mutyam,
As mentioned by Rfferrao13, you can use the Bulk Mods Tool to update the argument for that check command across multiple servers.
The only catch is that it will write over the whole argument field (e.g $ARG1$) if you are using the same token that should not be an issue.
Let me know if you have any questions.
Benjamin
