MSSQL WIZARD ERROR
joash0809
MSSQL WIZARD ERROR
Post by joash0809 »
Hi Support,
Currently, we are trying to monitor MSSQL DB via the MSSQL wizard. We encountered an error using the wizard to which we looked up in a nagios support forum that mentioned the limitation of the nagios wizard which is unable to accept special characters in the password. we followed the workaround provided in the forum which was to add the credentials into /usr/local/nagios/etc/resource.cfg. Upon doing so we still are facing the error, kindly assist this issue. attached is the relevant screenshots.
ssax
Dreams In Code
Re: MSSQL WIZARD ERROR
Post by ssax »
First, go to Admin > Manage Config Wizards and click the Check for Updates button and install any MSSQL wizard updates. There have been some recent updates and I want to make sure you have the latest.
Then go to Configure > Core Config Manager > Commands:
- Edit the command your service is using and surround the user/password values with single-quotes:
$USER1$/check_mssql_database.py -H $HOSTADDRESS$ -U '$USER11$' -P '$USER10$' $ARG1$
Then save and apply configuration, and test.
If you SSH into the XI server and run it as the nagios user, does it work?
su - nagios
/usr/local/nagios/libexec/check_mssql_database.py -H 10.202.12.98 -U 'username' -P 'password' -T 'master' -p 1443 --time2connect --warning 1 --critical 5
Send us the full output.
