NCPA Service check with Memory Usage option
Rago
Post by Rago »
Hello all,
Newbie with NCPA.
Currently I have a basic set up using Nagios Core on Ubuntu and a Windows machine running NCPA Client.
I manage to set up the basic monitoring for CPU, Memory and Service check.
My problem is, so far I only see the way to check if an specific service is running or not but I want to add a Memory check so I can trigger notification when this service reach a memory threshold.
I've been searching but can't any way to do it.
This is what I have so far to check y "myservice" is running or not
check_ncpa!-t 'nagiosncpa' -P 5693 -M 'services' -q 'service=myservice,status=running'
Any help will be really appreciatted
gormank
Re: NCPA Service check with Memory Usage option
Post by gormank »
It doesn't look like the API supports a memory used option for service checks.
Rago
Post by Rago »
Hi gormank,
Yes, you are right, at least I can't find anything related.
I think I will try NRPE (check_nrpe) to see my options.
Thank you very much for your reply
