Mismatch between NagiosXI and Azure Monitor output
ghosham
Post by ghosham »
I am reviewing one of our Azure VM configured at NagiosXI for infra monitoring, I realized, there is a big gap between what Azure depicts as CPU load and what NagiosXI shows:
From Azure:
From NagiosXI:
As you can observe, Azure says the avg is pegged at 73%, NagiosXI says 52%.
Why is there such a discrepency?
iirc, both the tools are set at avg CPU calculaition with 15 min interval.
Re: Mismatch between NagiosXI and Azure Monitor output
What command are you using to measure the load for this service in Nagios XI?
