Errors Upgrading Nagios XI
ei-admin
Post by ei-admin »
Not sure what to do please help :cry:
DATE: Wed Dec 2 17:32:44 PST 2020
DISTRO INFO:
CentOS
6.10
x86_64
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
Checking required prereqs...
Please wait...
OLD VERSION: 5610
Loaded plugins: fastestmirror
Setting up Update Process
Determining fastest mirrors
Error: Cannot find a valid baseurl for repo: base
YumRepo Error: All mirror URLs are not using ftp, http or file.
Eg. Invalid release/repo/arch combination/
removing mirrorlist with no valid mirrors: /var/cache/yum/x86_64/6/base/mirrorlist.txt
vtrac
Re: Errors Upgrading Nagios XI
Post by vtrac »
Hi ei-admin,
Please make sure that you do have internet connection.
Looks like CentOS 6 has reached End of Life (EOL) in November 30, 2020.
YUM might be attempting connect to deprecated repositories.
So, we need update deprecated repositories URL’s and point to the vault.
Resolution
To fix this problem you edit /etc/yum.repos.d/CentOS-Base.repo and comment out mirrorlist and replace baseurl with:
baseurl=http://vault.centos.org/6.10/os/$basearch
1. Go to /etc/yum.repos.d/ directory:
# cd /etc/yum.repos.d/
2. Make copy of original file:
# cp CentOS-Base.repo CentOS-Base.repo.old
3. Open and edit file with any text editor:
# vi CentOS-Base.repo
4. After editing it should looks like:
[base]
name=CentOS-$releasever - Base
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os&infra=$infra
[updates]
name=CentOS-$releasever - Updates
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates&infra=$infra
baseurl=http://vault.centos.org/6.10/updates/$basearch/
[extras]
name=CentOS-$releasever - Extras
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras&infra=$infra
baseurl=http://vault.centos.org/6.10/extras/$basearch/
[centosplus]
name=CentOS-$releasever - Plus
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus&infra=$infra
baseurl=http://vault.centos.org/6.10/centosplus/$basearch/
5. Clean yum cache
# yum clean all
6. Run again yum update command:
# yum update
Also, please consider update your system from CentOS 6 to CentOS 7 or 8.
Best Regards,
Vinh
ei-admin
Post by ei-admin »
# yum update
Didn't work ):
vtrac
Post by vtrac »
Hi ei-admin,
Please try edit the file named /etc/yum/pluginconf.d/fastestmirror.conf , run:
# vi /etc/yum/pluginconf.d/fastestmirror.conf
Find line that read as follows:
enabled=1
And set it as follows (set enabled to 0):
enabled=0
Save and close the file. Now run the following yum command:
# yum clean all
# yum update
Best Regards,
Vinh
vtrac
Post by vtrac »
Hi ei-admin,
My teammate has suggest the followings:
The errors are caused by Centos removing the Centos6 versions of the repositories and moving them to the vault.
What the customer need to do is to permanently disable the "base", "updates" and the "extras" repo's under the "/etc/yum.repos.d/CentOS-Base.repo" by editing the file and setting "enabled=0".
Then they need to edit the  "CentOS-Vault.repo" file and enable the base and updates section and that will remove the errors as the system will be pointing to servers that still exist.
Also, old cached of "mirrorlist.txt" files must be deleted as well:
/var/cache/yum/x86_64/6/updates/mirrorlist.txt
/var/cache/yum/x86_64/6/extras/mirrorlist.txt
Hope this helps.
Vinh
ei-admin
Post by ei-admin »
Different error now:
base | 3.7 kB 00:00
base/primary_db | 4.7 MB 00:03
http://mirror.centos.org/centos/6/cr/x8 ... repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: cr. Please verify its path and try again
This is what I have down for my centos-base.repo
[base]
mirrorlist=http://mirrorlist.centos.org/?release=$ ... fra=$infra
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-6
#released updates
[updates]
gpgcheck=1
#additional packages that may be useful
[extras]
gpgcheck=1
#additional packages that extend functionality of existing packages
[centosplus]
gpgcheck=1
enabled=0
#contrib - packages by Centos Users
[contrib]
name=CentOS-$releasever - Contrib
baseurl=http://mirror.centos.org/centos/$releas ... $basearch/
gpgcheck=1
enabled=0
I think we've almost got it!
vtrac
Post by vtrac »
Hi ei-admin,
You are getting the 404 error because those URL's mirrors were not available (supported) anymore for CentOS 6x.
We want to disable everything inside the "CentOS-Base.repo" and start using the "CentOS-Vault.repo" file for CentOS 6x.
From the list provided in your last reply, looks like not everything in the "CentOS-Base.repo" file were disabled.
I am only seeing "[centosplus]" and "[contrib]" sections were disabled.
We also want the "[Base]", "[Updates]" and "[Extras]" (sections) ALL to be disabled as well.
Please edit the "CentOS-Base.repo" file again and add "enabled=0" to the "[Base]", "[Updates]" and "[Extras]" sections  ....  Each section must have the "enable=0" set ....  or you can just rename the "CentOS-Base.repo" file to "CentOS-Base.repo.notUse".
Now, start using the "CentOS-Vault.repo":
Please make sure you set "enabled=1" to ALL the sections inside the "CentOS-Vault.repo" file.
# yum clean all
# yum update
Hope this helps!!
Vinh
benjaminsmith
Post by benjaminsmith »
HI @ei-admin,
I see you opened a ticket for this issue, # 942312, we'll close out this thread and continue troubleshooting this issue the ticket.
Best Regards,
Benjamin
