A few questions regarding your use of Nagios
akerikels46
Post by akerikels46 »
Hi everyone,
for my bachelor thesis I'm working on a mobile frontend for nagios. If you're working with Nagios, I would really appreciate it if you could answer some questions for me :)
How (and how often) do you interact with nagios? (Push, email, app, web, ...)
When interacting with Nagios, what works good for you? What doesn't work as good and how could the interaction be improved?
How many people other people are using (the same) Nagios with you? If more than one, how does communication work?
Feel free to answer only one question, interpret them in a way that seems more reasonable for you or simplify your answers. Anything helps, thanks for tanking the time :)
Cheers.
benjaminsmith
Re: A few questions regarding your use of Nagios
Post by benjaminsmith »
Very cool! Good luck with your project.
