nagvis. how to show % bandwidth
lilydalehs
Post by lilydalehs »
Hi All,
I'm slowly building some nagvis maps and have come across an issue with the links.
I am monitoring some switches via snmp and when I put those onto the nagvis map I get a data transfer rate, not a percentage of bandwidth use. Attached is the image I'm referring to.
I have nagios monitoring that switch as well as the bandwidth on the port in question. This is what's returned by nagios.
OK - Current BW in: .17Mbps Out: .43Mbps
The command used to monitor that port is
check_xi_service_mrtgtraf!7995csw-srv01.curric.lilydale-hs.wan_19.rrd!500.0,500.0!800.0,800.0!M
I'm assuming I somehow have to get nagios to also return a percentage bandwidth? How do I go about that?
Regards,
Chris.
ps. the references above are to the left hand of the two links displayed.
cdienger
Re: nagvis. how to show % bandwidth
Post by cdienger »
You would need a plugin that returns percentage. Something like https://exchange.nagios.org/directory/P ... 64/details appears to do the trick. Integrating a plugin with XI is covered in https://assets.nagios.com/downloads/nag ... ios-XI.pdf.
lilydalehs
Thanks for the info. I will have a look into that.
Cheers,
Chris.
benjaminsmith
Post by benjaminsmith »
Hi Chris,
Sounds good. Let us know if you have any other questions.
SteveBeauchemin
Post by SteveBeauchemin »
Look in Nagios Exchange for iftraffic64 - It states that it is NagVis friendly. I use it for my SNMP tests and it does the job.
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
benjaminsmith
Some good info. Thanks, Steve!
