CentOS Linux release 6.0 (Final)
32 bit
VMware Image
While upgrading using the Source Installer package I run into this message and the installation halts. It doesn't appear to be logging into /tmp/install.log so I copied my putty session out.
Error: Package: nagiosxi-deps-2011r3.0-1.noarch (/nagiosxi-deps-2011r3.0-1.noarch)
Requires: php-pear-HTML-Template-IT
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
install.log
