Could not connect to odbc:Driver=FreeTDS
btayl
Post by btayl »
ERROR: [run_check] CRITICAL: Could not connect to odbc:Driver=FreeTDS;Server=172.20.148.23;Port=1433 as umhs\entmondba (Exception: SQLSTATE[01000] SQLDriverConnect: 0 [unixODBC][Driver Manager]Can't open lib 'FreeTDS' : file not found)
vtrac
Re: Could not connect to odbc:Driver=FreeTDS
Post by vtrac »
Hi btay,
Could you please check and see if "feetds" is installed?
# rpm -qa | grep -i freetds
Here are what I have with my Nagios XI (CentOS 7.8):
freetds-1.1.20-1.el7.x86_64
freetds-libs-1.1.20-1.el7.x86_64
freetds-devel-1.1.20-1.el7.x86_64
If you don't have freetds libs, please try the install command below:
# yum install freetds freetds-libs freetds-devel
Best Regards,
Vinh
btayl
Post by btayl »
It is installed
[root@nagios-va-ps1a ~]# rpm -qa | grep -i freetds
I see a ticket is now open for the same issue.
Locking thread to prevent duplicate work
