When running the upgrade script it stops with the following error:
nagiosxi-deps-2011r3.0-1.noarch from /nagiosxi-deps-2011r3.0-1.noarch has depsolving problems
--> nagiosxi-deps conflicts with nagios-nrpe
Error: nagiosxi-deps conflicts with nagios-nrpe
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
I'm upgrading our Nagiosxi install on RHEL 5. Thanks!
Nagios 2011R3.0 from 2011R2.4 problem
Re: Nagios 2011R3.0 from 2011R2.4 problem
We've added some extra checks in our upgrade script, getting prepared for our next release. Don't worry about this error - it will not cause any loss in functionality. Your upgrade has completed successfully (besides this message), right?
Thanks for the information. Yeah, when I log into the web interface it says that it completed successfully. I just wanted to make sure that everything was OK.
Yeah, we're currently working out the best way to handle "post XI install" package conflicts with our upgrade script. So at this very moment this is a known issue with the upgrade script returning those errors. We hope to have this taken care of sometime next week, but in the meantime, the actual upgrade should have occurred successfully.
I faced with the same problem, but could managed with it by handle.
And today, when I entered the nagios I saw, that you guys released a new version
This is not fair
Yeah, sorry about that, 3.1 was a bug fix release. We had an line in our installer that was at risk of removing user defined crontab entries and we wanted to get that out of there ASAP. If you've got 3.0 these are the only actual changes for 3.1.
2011R3.1 - 06/08/2012
- Fixed issue with upgrade script that could remove user-defined cron jobs from root crontab - SW
- Fixed bug created in 3.0 where '/' was not allowed in service descriptions - MGRe: Nagios 2011R3.0 from 2011R2.4 problem
Is it actual for me now to move to 3.1? Or I can stay on 3.0?
Everything seem works fine.
Using the 3.0 release instead of 3.1 will function properly, however 3.1 did include bug fixes see:
http://assets.nagios.com/downloads/nagi ... S-2011.TXT
