Hello team,
Can we monitor License expiry for some software using Nagios XI? Or License renewal date?
License monitoring
Re: License monitoring
Yes, XI would be able to run a plugin that checks a license's expiration/renewal information. Some examples are here:
https://exchange.nagios.org/index.php?o ... rd=license
kalyanpabolu
Thanks for your reply!!
I checked those plugins, but all of them are specific to software. Is there any common plugin to monitor license for all software?
Or any configuration Wizard you can suggest here?
An example of a custom script that finds the difference between the current date and a date supplied can be found at https://support.nagios.com/forum/viewto ... 16&t=59971.
