Marking HostGroups active/deactive
dh0125e
Post by dh0125e »
When we push our Services between XI's the hostgroups that are referenced are created automatically (which is good) however they are set Active=False (which is bad). How do we enable these host groups via the API? I can't find anything in the API for this.
dchurch
Re: Marking HostGroups active/deactive
Post by dchurch »
You're not missing anything in the documentation. Unfortunately making a hostgroup or a servicegroup active or inactive isn't supported by the API currently.
Ideally, one should be able to make the change by sending a PUT request with is_active=1 to the API under http://example.com/nagiosxi/api/v1/conf ... group-name, or -- even better -- with the POST request that created the group, but these fields aren't supported by the API (yet).
I can submit a feature request on your behalf if you'd like. Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
dh0125e
Post by dh0125e »
Yes this is a going to cause a large amount of extra manual effort to go behind the automations to "finish" monitoring applications.
dchurch
Post by dchurch »
Okay, I've submitted the feature request to our dev team. With any luck it will be available in the next release cycle.
Subject: Add is_active support to hostgroup/servicegroup API
Summary:
Please add support for setting and changing the "active" field in:
- PUT /config/{host,service}group/{name}
- POST /config/{host,service}group
Please also update the doc to reflect the request format you go with.
