Centos6 to Centos 7 Migration - /nagios up /nagiosxi db erro
phamanth
Post by phamanth »
We have just performed a centos 7 migration by using a manual backup and restoring on the Centos 7 box via the backupxi and restorexi scripts.
Those both ran successfully. Afterwards, we did the restore repair script and that looks like it ran correctly as well. The /nagiosxi page still gives a Database error page but the /nagios is running. I am assuming this may be due to a httpd configuration? Please assist. Thank you.
dchurch
Re: Centos6 to Centos 7 Migration - /nagios up /nagiosxi db
Post by dchurch »
If you PM me a system profile I can diagnose further. Get one by going to Admin (top menu) => System Profile (in the left menu), then clicking the blue button.
If you're unable to generate the the profile through the web interface, please try generating it from the command line by running these commands as root:
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
Then send me the resulting /usr/local/nagiosxi/var/components/profile.zip file.
If the profile script fails, please include the ENTIRE output.
phamanth
Post by phamanth »
Probably other similar posts about this issue, but my issue was caused by the db passwords in the restore process. Once the passwords to the databases were squared away, was able to access the nagiosxi page.
benjaminsmith
Post by benjaminsmith »
HI,
Great! Glad you got it solved. Did you need anything else or shall we close this out?
