We onboarded status and bandwidth service with total 50K services. But when see graph of bandwidth services, it only updated till yesterday's data.
Perfomance Graph data not updated
benjaminsmith
Re: Perfomance Graph data not updated
That's a lot of checks for a single XI server, and the system is likely not able to process the incoming graphs as it should.
Have you made any performance adjustments so far? If you haven't done so already, you'll want to boost the load threshold and timeout for the performance graph component, the steps are in the following guide.
Nagios XI - Performance Graph Problems
Also, take a look at the following guide. I would recommend spacing out the check interval as much as possible to reduce the number of checks needed to execute for a given time period.
Maximizing Performance In Nagios XI
Benjamin
Benjamin
Thanks for your advice.
It worked after we change the parameters.
Great!rragha2 wrote:Thanks for your advice.
Locking thread
