Hi all,
I'm looking to replace our solarwinds implementation with Nagios for a few reasons. The problem I'm running into is all the options and legacy documentation. I'm currently eyeballing Nagios Core, running NRDP, and NCPA. Is this a typical setup? I've been bounced between NRPE and NSCA, then I learn that NCPA is a thing. I'm just trying to find the bottom of the worm hole for planning before I do any further work on implementation.
So I guess the question is, if you were to roll out a Nagios Core installation today, how would you do it?
Also, anybody have experience with Nagios XI vs Nagios Core?
Looking at nagios as a solarwinds replacement, need advice
edugatei56
benjaminsmith
Re: Looking at nagios as a solarwinds replacement, need advi
Thanks for posting to the community forum and more than happy to help you get started with Nagios!
For configuring passive checks, then I would use NRDP instead of NSCA as it is a newer application the uses HTTP for communications. NCPA can also be setup passively to communicate check results over NRDP.
https://assets.nagios.com/downloads/ncp ... Checks.pdf
If you going to be monitoring a large network, Nagios XI is going to be much easier to manage and configure. We do have a 30-day trial available with access to the support team for help.
For setup help with Nagios Core, check out the official docs, they are very detailed.
https://assets.nagios.com/downloads/nag ... index.html
Hope that helps answer some of your questions.
Benjamin
That really depends on your environment, how large it is, and what types of service checks you want to set up. For running checks via an agent, NCPA is the recommended application.So I guess the question is, if you were to roll out a Nagios Core installation today, how would you do it?
Benjamin
