Team,
Require plug in to check folder in a path for windows server.
please suggest on this. Thanks in Advance
Plug in for folder check
Re: Plug in for folder check
1. What is your server topology like?
2. Is this folder part of a Windows shared folder? Can you mount it somewhere? Is it mounted somewhere on the Nagios XI server?
3. Are you using NCPA to run any checks on the Windows server already?
4. What are you checking about the folder?
5. What are the requirements for monitoring the server itself: If the server is down do you want a notification? Are there already notifications in place for this?
Hi Dchurch,
Thanks for your response.
It is a application server, and which process the transaction logs
yes..the folder is part of windows server and folder mounted in same server to one of the disk and its not mounted in nagios server
we are using check_file plug in to check the files in folder at particular time. but this time we want to check the folder in shared path.
we have a path in server, at some point of time files processed in a folder and archived in sometime.if files doesn't processed in that folder
nagios has to trigger alert like files not processed in folder
we have already placed all services in monitoring for that server.
Thanks in advance for for your reply.
Regards,
Chandra
Regards,
Chandra
Unfortunately NCPA doesn't have a way to do this out of the box. You might find a plugin on the Exchange to check file count, sizes, etc. If you can, then you could add that to NCPA's plugins directory, and perform your check that way.tchandra wrote:we have a path in server, at some point of time files processed in a folder and archived in sometime.if files doesn't processed in that folder
This can be done with NRPE, however. Here's an example folder file count check using check_nrpe:
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -c check_files -a path='D:\\import\\faxin' pattern=*.* 'warning=count>100' 'critical=count>150'See also this forum post for someone with a similar monitoring task.
