I'm trying to configure nrpd at nagios XI to receive checks from our old nagios, I configured server-side, now how I want to configure client-side to send host and service checks from old nagios, if I send a test check manually with send_nrpd.php it works correctly, check is received by nagios XI at Unconfigured Objects page. Now... how must I configure old nagios to send hosts ande services checks to nagios XI? I was searching at documentation but I cant' find how to make this...
Thanks.
nrdp distributed environment
Re: nrdp distributed environment
I 've solved this issue following the instructions in this link http://nagios.sourceforge.net/docs/3_0/distributed.html, but instead of using nsca I used nrdp, it woks fine.
Glad you got it working! That's actually the exact doc we would have sent ; )
