Monitor Apache Tomcat list applications
fsodah
Post by fsodah »
is there a way to monitor Apache Tomcat list applications status?
as I have apache tomcat installed on a server and has a lot of applications running on it and I want to monitor all the applications status running on it
dchurch
Re: Monitor Apache Tomcat list applications
Post by dchurch »
What specifically do you want to monitor about the applications?
Nagios XI already provides a wizard to set up monitoring of an Apache Tomcat server. Are you running into issues setting that up?
fsodah
Post by fsodah »
Already Done using the wizard.
dchurch
Post by dchurch »
Okay, sounds like you got this working. I'll close the topic.
For any new issues, feel free to start a new topic. :-)
