Hello i am following this guide Integrating_Network_Analyzer_With_Nagios_Core_And_Nagios_XI.pdf to integrate Nagios NA with Nagios XI and when configuring the NRDP token/alerting in NA and apply configuration to Nagios XI nothing is showing under "Unconfigured Objects". Any ideas on what im missing?
I have confirmed the following:
1. Nagios NA can access the Nagios XI instance on port 443
2. Tested accessing the NRDP API URL and manually entering key and submitting, then i can see a test object in "Unconfigured Objects" within Nagios XI
3. Ive tried updating to IP address instead of host-name within Nagios NA configutaion
NA NRPD Integration issue
Re: NA NRPD Integration issue
On the NNA command line, create a file with these contents:
and then run:
Make sure to replace XI_IP, TOKEN, and FILENAME with the correct ip, token, and filename. Let us know if this command is successful in creating a host and service in under the unconfigured objects section of XI.
<?xml version='1.0'?>
<checkresults>
<checkresult type='host'>
<hostname>somehost</hostname>
<state>0</state>
<output>Everything looks okay! | perfdata=1;</output>
</checkresult>
<checkresult type='service'>
<servicename>someservice</servicename>
<state>1</state>
<output>WARNING: Danger Will Robinson! | perfdata=1;</output>
</checkresult>
</checkresults>Code: Select all
curl -XPOST https://XI_IP/nrdp/ -d token=TOKEN -d cmd=submitcheck --data-urlencode xml@FILENAME -k -vAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
