We have a Nagios XI installation on CentOS Linux.
The graphs (all of them) are stopped working after installing the new wizard for MySQL (from Nagios library).
Instead of graphs I see the empty area (see attached file).
Please advise on how can we pinpoint and fix this issue.
Thanks in advance!
-Mic.
No Graphs
tonyyarusso
Re: No Graphs
This wizard is new, so I'm not sure if it has a different issue, but others have had similar issues with graphing that were solved by resetting the security credentials, so you could try that first.
Re: No Graphs
Resetting Security credentials fixed this issue.
thank you for your prompt answer !
