Disk Root getting full with DB log
tchandra
Post by tchandra »
Hi Team,
we have one of Nagios Worker server and it has root partition. Recently, we are getting space issue for disk root.Then i checked and found that
Maria db log under /var/log is occupying more space and i am unable to compress it as it is a live log. Can someone please suggest on this to clear the space issue.
Thanks in advance.
Regards,
Chandra
cdienger
Re: Disk Root getting full with DB log
Post by cdienger »
Stop the service and then try deleting the log:
systemctl stop mariadb
Keep an eye on the log after you restart it. If it growing quickly then that can be a sign of a problem and we'll want to take a look at the log.
tchandra
Post by tchandra »
Hi cdienger ,
Thanks for the response.
You suggested to delete the db log after stopped the service. if i can delete the log, is there any problem occurs in Nagios or not.
can you please suggest on this.
Thanks in Advance.
Regards,
Chandra
cdienger
Post by cdienger »
No, XI doesn't need the log. It does need the database service though so when you go to remove the log do it quickly:
rm -f /var/log/mariadb/mariadb.log
systemctl start mariadb
Make sure nagios is still running afterwards:
systemctl status nagios
and restart it if needed:
systemctl restart nagios
tchandra
Post by tchandra »
Hi cdienger ,
Thanks for suggestion. Anyhow , we have cleared the space and issue is fixed now.
tchandra wrote:Hi cdienger ,
Great!
Locking thread
