I plan to migrate a data center with thousands of servers, switches, etc from Nagios Core to Nagios XI in the coming days.
As the underlying engine for XI is Core, I would expect I can import my Core.cfg files into XI ....somehow.
Is there a document on performing that change?
Ben
Migrte from Core to XI
Re: Migrte from Core to XI
Below are a couple of documentation links that you can use to migrate and import the config files from a Core server in to XI.
https://library.nagios.com/library/prod ... -prep-tool
https://library.nagios.com/library/prod ... es-into-xi
The import tool is in the Core Config Manager menu in the XI interface.
