Nagios Monitoring Teams in the Azure Cloud
xxandyxx
Post by xxandyxx »
Hello Everyone,
does someone happen to know a plugin with which MS Teams can monitor in the Azure cloud.
Nagios shouldn’t send messages to teams, just check whether the application is available in the Azure cloud.
“PS1 files are not supported”.
Maybe someone happens to know a Python script or something similar.
Thank you for your support …
