Update Check Problem: Last update check failed.
gkrono
Post by gkrono »
hello,
I am getting this error Update Check Problem: Last update check failed.
And also un able to receive email notifications
dchurch
Re: Update Check Problem: Last update check failed.
Post by dchurch »
Hi gkrono!
What distro are you running? What version of Nagios XI?
Are you running your Nagios XI server in an offline environment?
Can you log into the Nagios XI server and run the following command:
getent hosts api.nagios.com
gkrono
Post by gkrono »
hello,
What version of Nagios XI? Nagios XI 5.7.5
Are you running your Nagios XI server in an offline environment?NO
[root@localhost ~]# getent hosts api.nagios.com
[root@localhost ~]#
run the command but no change
gkrono
Post by gkrono »
hello dchurch
i resolve by changing dns configuration on nangiosxi server
on vi /etc/resolv.conf to fit to my current dns IPS
Thanks for your support
gkrono wrote:hello dchurch
Great!
Locking thread
