We're trying to setup UDP port checks across four Windows 2019 servers in Nagios XI (5.6.14) using the Configuration Wizard. The port we're trying to monitor is UDP port 1812 (Authentication). The Configuration Wizard requires we supply send/receive strings. My question is where can I find those strings? I uploaded a screen shot of what I'm referring to in the Configuration Wizard.
Thanks ahead of time
UDP Port Monitors
FrontlineIT
UDP Port Monitors
Re: UDP Port Monitors
The strings are arbitrary here, but they represent what data the service takes in (i.e. the send string), and what should be expected back (i.e. the receive string).
Port 1812/udp tells me this is a RADIUS server.
In this case I think you could instead use the check_radius.py plugin that Nagios XI ships with. For ease of use, this can be set up using the RADIUS Server wizard.
FrontlineIT
Is there more documentation on this for the RADIUS Server wizard? Duo provides a client secret but I don't believe there is a username/password for this.
The User Name and password would be a user name and password for an account on the RADIUS server.
Beyond that, here's the help text from the script:
Usage: check_radius.py [options]
Options:
-h, --help show this help message and exit
-V, --version Print the version number of the plugin
-v, --verbose Print out verbose output
-H HOSTNAME, --hostname=HOSTNAME
The hostname of the RADIUS server to connect to
-P PORT, --port=PORT The port of the RADIUS server
-u USERNAME, --username=USERNAME
The username to authenticate
-p PASSWORD, --password=PASSWORD
The password of the auth user
-s SECRET, --secret=SECRET
The shared secret for the RADIUS server
-t TIMEOUT, --timeout=TIMEOUT
The amount of time to try to authenticate before
timing out
-r RETRIES, --retries=RETRIES
The number of authentication retries
-c CHRESPONSE, --chresponse=CHRESPONSE
Response to challenge message
-a ATTRIBUTES, --attributes=ATTRIBUTES
Location of attributes fileIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
