Hello Dears,
I have an issue during try to upgrade Nagios from version 5.7.1 to 5.7.5.
Please check the below error and advise.
---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Backing up Nagios Core...
tar: Removing leading `/' from member names
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up the SNMP directories
Backing up NRDP...
Backing up Nagvis...
Backing up nagios user home dir...
Backing up MySQL databases...
mysqldump: Got error: 29: "File './nagios/nagios_hostchecks.MYD' not found (Errcode: 5)" when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
Auto Upgrade Nagios XI 5.7.5 error
Re: Auto Upgrade Nagios XI 5.7.5 error
Hi Emad,
Looks like your password might have been changed by your team.
Can you log into the mysql database manually?
What is the password that is set in the "automysqlbackup" script?
Regards,
Vinh
mysql -uroot -pnagiosxi
or
mysql -uroot -p<your new password>
grep -i password= /root/scripts/automysqlbackup | head -n 1
Vinh
