Hi guys,
im trying to monitor my cisco ise 2.6 with nagios. But on google i cant found something usefull.
I tryied plugin but they are too old, and the oid doesnt work. Also mib tree are not so clear.
I tryied also generic cisco plugin without success.
Thank you so much if someone can help me.
Cisco ise Nagios monitoring trought OID?
EleanorCooper
- StefanAlbrecht
Re: Cisco ise Nagios monitoring trought OID?
HOST-RESOURCES-MIB should prodive you with the required data. You may check the supported SNMP MIBs mentioned by Thomas here:
https://community.cisco.com/t5/network- ... -p/4278278
domyhomeworkonline.net
Cisco user id: Stefan Albrecht
