Hello Forum,
I am new member.
I am trying to graph my Brocade & Sonicwall switch bandwidth. However, I need help in activating the graph explorer. I have imported the component how do not know how to activate or generate graphs. Please advise.
Sincerely,
Samson
Graph Explorer
Re: Graph Explorer
If there is performance data for this service, you should be able to access the performance graphs from the Home->Graph Explorer->Timeline(tab). Locate the host that you want to view data for, then select the individual service. The service will only be listed if there is performance data for it.
