Here are the reliant pieces of the configuration. I'm changed a bunch of the names so these examples may not be technically correct.
Service Template
name service_tpl
register 0
max_check_attempts 2
check_interval 5
retry_interval 5
check_period 24x7
notification_period 24x7
notification_interval 5
notification_options w,u,c,r
}Code: Select all
define contact {
name contact_tpl
register 0
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period 24x7
service_notification_period 24x7
host_notification_options d,u,r
service_notification_options w,u,c,r
service_notification_commands notify-service-by-email
host_notification_commands notify-host-by-email
}Code: Select all
define contactgroup {
contactgroup_name example-contactgroup
members example-member
}Code: Select all
define contact {
use contact_tpl
contact_name example-member
name example-member
email [email protected]
}Code: Select all
use service_tpl
hostgroup example-hostgroup
service_description storage_root
check_command check_storage!$HOSTADDRESS$!/!50!75
contact_groups example-contactgroup
}Code: Select all
define serviceescalation {
hostgroup *
service_description *
first_notification 1
last_notification 2
escalation_options u,c,r,w
