Netapp devices monitoring
kalyanpabolu
Hello Team,
We want to monitor NetApp Storage devices using Nagios XI. Could you please guide us on the same?
We would like to monitor below parameters:
1. Volume space utilization
2. Aggregate space utilization
3. On/off status of volumes/LUNs
4. CPU status of storage
5. Memory usage
6. Capacity logs on aggregate level
Thanks in advance!!
5. Memory usage
Thanks in advance!!
kalyanpabolu
Re: Netapp devices monitoring
Can we please get an update here?
benjaminsmith
Hi @kalyanpabolu,
I did some research on this and I would suggest trying one or more of the community plugins for NetApp available on the Nagios Exchange.
Most of these are perl scripts using SNMP to query metrics from the NetApp system. For example, the Check Netapp NG plugin will check:
https://exchange.nagios.org/directory/P ... NAS/NetApp
Alternatively, you could use of the generic SNMP wizards in Nagios XI to configure this, assuming, you know which OID's you want to run check against.
Let me know if you have any specific questions.
References:
Managing Plugins In Nagios XI
https://www.nagios.com/solutions/snmp-monitoring/
The full listing is available at:Temperature
* Fan Fail
* Power Supply Fail
* CPU Load
* NVram Battery Status
* Vol Usage Precentage
* Snapshot Config
* Shelf Health
* Number of ndmp sessions
* Global Status of the filer
* Number of failed disks
* Show's uptime
* Cache Age
References:
kalyanpabolu
Thank you for the reply!!
We will go through the plugin and get back to you with the updates!!
Sounds good, we'll keep an eye out.
kalyanpabolu
We checked one plugin and it seems to be working fine. The disk usage is getting below output:
[root@HO1-NAGIOSXI libexec]# ./check_netapp3.pl -H 172.16.10.5 -v DISKUSED64
Use of uninitialized value $volume in substitution (s///) at ./check_netapp3.pl line 488.
Use of uninitialized value $volume in sprintf at ./check_netapp3.pl line 489.
DISKUSED64 OK - Kb used : 28120955260|du_ = 28120955260
I am not sure why some error message it is giving. Also, can we get the output in Mb?
You should be able to comment out this line in the plugin to ignore those:
To this:
Then run the check again and see if they still show.
use warnings;Code: Select all
#use warnings;-
kalyanpabolu
Thanks for the reply!!
It worked fine and removed those warnings.
DISKUSED64 OK - Kb used : 28121238268|du_ = 28121238268
Can we get the output in MB?
benjaminsmith
HI,
Regards,
Benjamin
Reference:
http://oidref.com/1.3.6.1.4.1.789.1.5.4.1.4
https://exchange.nagios.org/components/ ... 2&cf_id=24
The OID is returning KB for this plugin and I don't see any options for converting to MB ( so it would need to be modified).Can we get the output in MB?
Regards,
Benjamin
Reference:
kalyanpabolu
Sorry, I didnt get this.
Do you want me to modify script? If yes, what changes needs to be done?
